On the illumination invariance of the level lines under directed light. Application to change detection. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) SIAM Journal on Imaging Sciences Année : 2008
We analyze the illumination invariance of the level lines of an image. We show that if the scene surface has Lambertian reflectance and the light is directed, then a necessary condition for the level lines to be illumination invariant is that the 3D scene be developable and that its albedo satisfies some geometrical constraints. We then show that the level lines are ``almost'' invariant for piecewise developable surfaces. Such surfaces fit most of the urban structures. In a second part, this allows us to devise a very fast algorithm that detects changes between pairs of remotely sensed images of urban areas, independently of the lighting conditions. We show the effectiveness of the algorithm both on synthetic OpenGL scenes and real Quickbird images. We compare the efficiency of the proposed algorithm with other classical approaches and show that it is superior both in practice and in theory.
RR-6612.pdf (1.6 Mo) Télécharger le fichier
inria-00310383 , version 1 (08-08-2008)
  • HAL Id : inria-00310383 , version 1
Pierre Weiss, Alexandre Fournier, Laure Blanc-Féraud, Gilles Aubert. On the illumination invariance of the level lines under directed light. Application to change detection.. [Research Report] RR-6612, INRIA. 2008, pp.36. ⟨inria-00310383⟩
315 Consultations
146 Téléchargements
