s'authentifier
version française rss feed
inria-00311300, version 1
Model Driven Engineering Benefits for High Level Synthesis
Sébastien Le Beux () 12, Philippe Marquet () 12, Jean-Luc Dekeyser () 12
N° RR-6615 (2008)
Résumé : This report presents the benefits of using the Model Driven Engineering (MDE) methodology to solve major difficulties encountered by usual high level synthesis (HLS) flows. These advantages are highlighted in a design space exploration environment we propose. MDE is the skeleton of our HLS flow dedicated to intensive signal processing to demonstrate the expected benefits of these software technologies extended to hardware design. Both users and designers of the design flow benefit from the MDE methodology, participating to a concrete and effective advancement in the high level synthesis research domain. The flow is automatized from UML specifications to VHDL code generation and has been successfully evaluated for the conception of a video processing application.
  • Domaine : Informatique/Architecture
  • Référence interne : RR-6615
  • inria-00311300, version 1
  • oai:hal.inria.fr:inria-00311300
  • Contributeur :
  • Soumis le : Mercredi 13 Août 2008, 19:02:25
  • Dernière modification le : Mercredi 10 Septembre 2008, 15:35:19
tous les articles de la base du CCSd...
