Execution Time of $\lambda$-Terms via Denotational Semantics and Intersection Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The multiset based relational semantics for linear logic induces a semantics for the type free $\lambda$-calculus. This one is built on non-idempotent intersection types. We prove that the size of the derivations and the size of the types are closely related to the execution time of $\lambda$-terms in a particular environment machine, Krivine's machine.
RR-6638.pdf (422.86 Ko) Télécharger le fichier
inria-00319822 , version 1 (09-09-2008)
  • HAL Id : inria-00319822 , version 1
Daniel de Carvalho. Execution Time of $\lambda$-Terms via Denotational Semantics and Intersection Types. [Research Report] RR-6638, INRIA. 2008, pp.39. ⟨inria-00319822⟩
117 Consultations
90 Téléchargements
