State of the Art: Updating Delaunay Triangulations for Moving Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This paper considers the problem of updating efficiently a two-dimensional Delaunay triangulation when vertices are moving. We investigate the three current state-of-the-art approaches to solve this problem: --1-- the use of kinetic data structures, --2-- the possibility of moving points from their initial to final position by deletion and insertion and --3-- the use of "almost" Delaunay structure that postpone the necessary modifications. Finally, we conclude with a global overview of the above-mentioned approaches while focusing on future works.
RR-6665.pdf (188.28 Ko) Télécharger le fichier
inria-00325816 , version 1 (30-09-2008)
  • HAL Id : inria-00325816 , version 1
Olivier Devillers, Pedro Machado Manhães de Castro. State of the Art: Updating Delaunay Triangulations for Moving Points. [Research Report] RR-6665, INRIA. 2008, pp.12. ⟨inria-00325816⟩
263 Consultations
458 Téléchargements
