EMACOP : Environnement Multimédia pour l'Acquisition et la gestion de COrpus Parole - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
This paper presents an Multimedia Environment for Acquiring and Managing Speech Corpora, running under Windows 95 and windows NT. It provides graphical interface functions to process the signal in order to compute acoustical parameters used in speech analysis, recognition and synthesis. Entries' extraction from main database is also provided from other sources. The new way of programming through the Microsoft COM (Component Object Model), which gives encapsulation/aggregation mechanisms and independence for each module, is used to increase reliability, flexibility and maintainability.
Vaufreydaz98a.pdf (87.44 Ko) Télécharger le fichier
inria-00326144 , version 1 (01-10-2008)
  • HAL Id : inria-00326144 , version 1
Dominique Vaufreydaz, Mohamad Akbar, Jean Caelen, Jean-François Serignat. EMACOP : Environnement Multimédia pour l'Acquisition et la gestion de COrpus Parole. JEP'98 (Journées d'Étude sur la Parole), Jun 1998, Martigny, Suisse. pp. 175-178. ⟨inria-00326144⟩
98 Consultations
93 Téléchargements
