A Corpus Balancing Method for Language Model Construction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The language model is an important component of any speech recogn ition system. In this paper, we present a lexical enrichment methodology of corpora focused on the construction of statistical language models. This methodology considers, on one hand, the identification of the set of poor represented words of a given training corpus, and on the other hand, the enrichment of the given corpus by the repetitive inclusion of selected text fragments containing these words. The first part of the paper describes the formal details about this methodology; the second part presents some experiments and results that validate our method.
Villasenor03a.pdf (41.54 Ko) Télécharger le fichier
inria-00326515 , version 1 (03-10-2008)
  • HAL Id : inria-00326515 , version 1
Luis Villaseñor-Pineda, Manuel Montes-Y-Gómez, Manuel Pérez-Coutiño, Dominique Vaufreydaz. A Corpus Balancing Method for Language Model Construction. Fourth International Conference on Intelligent Text Processing and Computational Linguistics (CICLing-2003), Feb 2003, Mexico City, Mexico. 9 p. ⟨inria-00326515⟩
89 Consultations
247 Téléchargements
