Rate versus synchrony code for human action recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We propose a bio-inspired feedforward spiking network modeling two brain areas dedicated to motion (V1 and MT), and we show how the spiking output can be exploited in a computer vision application: action recognition. In order to analyze spike trains, we consider two characteristics of the neural code: mean firing rate of each neuron and synchrony between neurons. Interestingly, we show that they carry some relevant information for the action recognition application. We compare our results to Jhuang et al. (2007) on the Weizmann database. As a conclusion, we are convinced that spiking networks represent a powerful alternative framework for real vision applications that will benefit from recent advances in computational neuroscience
RR-6669.pdf (1.94 Mo) Télécharger le fichier
inria-00326588 , version 1 (03-10-2008)
  • HAL Id : inria-00326588 , version 1
Maria-Jose Escobar, G. Masson, Thierry Viéville, Pierre Kornprobst. Rate versus synchrony code for human action recognition. [Research Report] RR-6669, INRIA. 2008, pp.36. ⟨inria-00326588⟩
253 Consultations
441 Téléchargements
