Video Surveillance using a Multi-Camera Tracking and Fusion System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Zhong Zhang
  • Fonction : Auteur
Andrew Scanlon
  • Fonction : Auteur
Weihong Yin
  • Fonction : Auteur
Li Yu
  • Fonction : Auteur
Usage of intelligent video surveillance (IVS) systems is spreading rapidly. These systems are being utilized in a wide range of applications. In most cases, even in multi-camera installations, the video is processed independently in each feed. This paper describes a system that fuses tracking information from multiple cameras, thus vastly expanding its capabilities. The fusion relies on all cameras being calibrated to a site map, while the individual sensors remain largely unchanged. We present a new method to quickly and efficiently calibrate all the cameras to the site map, making the system viable for large scale commercial deployments. The method uses line feature correspondences, which enable easy feature selection and provide a built-in precision metric to improve calibration accuracy.
1569140044.pdf (330.78 Ko) Télécharger le fichier
inria-00326754 , version 1 (05-10-2008)
  • HAL Id : inria-00326754 , version 1
Zhong Zhang, Andrew Scanlon, Weihong Yin, Li Yu, Péter L. Venetianer. Video Surveillance using a Multi-Camera Tracking and Fusion System. Workshop on Multi-camera and Multi-modal Sensor Fusion Algorithms and Applications - M2SFA2 2008, Andrea Cavallaro and Hamid Aghajan, Oct 2008, Marseille, France. ⟨inria-00326754⟩
Collections
M2SFA2
236 Consultations
1616 Téléchargements
