Semantic Foundations and Inference of Non-null Annotations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper proposes a semantics-based automatic null pointer analysis for inferring non-null annotations of fields in ob ject- oriented programs. The analysis is formulated for a minimalistic OO language and is expressed as a constraint-based abstract interpretation of the program which for each field of a class infers whether the field is definitely non-null or possibly null after ob ject initialization. The analysis is proved correct with respect to an operational semantics of the mini- malistic OO language. This correctness proof has been machine checked using the Coq proof assistant. We also prove the analysis complete with respect to the non-null type system proposed by F ̈ahndrich and Leino, in the sense that for every typable program the analysis is able to prove the absence of null dereferences without any hand-written annotations. Experiments with a prototype implementation of the analysis show that the inference is feasible for large programs.
fmoods08.pdf (345.17 Ko) Télécharger le fichier
inria-00332356 , version 1 (20-10-2008)
  • HAL Id : inria-00332356 , version 1
Laurent Hubert, Thomas Jensen, David Pichardie. Semantic Foundations and Inference of Non-null Annotations. 10th International Conference on Formal Methods for Open Object-based Distributed Systems (FMOODS'08), 2008, Oslo, Norway. ⟨inria-00332356⟩
101 Consultations
133 Téléchargements
