Frame Rate Object Extraction from Video Sequences with Self Organizing Networks and Statistical Background Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In many computer vision related applications it is necessary to distinguish between the background of an image and the objects that are contained in it. This is a difficult problem because of the double constraint on the available time and the computational cost of robust object extraction algorithms. This paper builds upon former work on combining the strong theoretical foundations of clustering with the speed of other approaches. It is based on a novel Self Organizing Network (SON) which has a robust initialization schema and is able to find the number of objects in an image or grid. The main contribution of our extension is that it eliminates the use of a threshold, allowing the algorithm to work on continuous, while having a complexity that remains linear with respect to the number of pixels or cells.
main.pdf (98.2 Ko) Télécharger le fichier
inria-00333071 , version 1 (22-10-2008)
  • HAL Id : inria-00333071 , version 1
Thiago Craesmeyer Bellardi, Dizan Alejandro Vasquez Govea, Christian Laugier. Frame Rate Object Extraction from Video Sequences with Self Organizing Networks and Statistical Background Detection. IEEE/RSJ 2008 International Conference on Intelligent Robots and Systems, Sep 2008, Nice, France. ⟨inria-00333071⟩
355 Consultations
162 Téléchargements
