A Hybrid Algorithm for the Unbounded Knapsack Problem
This paper presents a new approach for exactly solving the Unbounded Knapsack Problem (UKP) and proposes a new bound that was proved to dominate the previous bounds on a special class of UKP instances. Integrating bounds within the framework of sparse dynamic programming led to the creation of an efficient and robust hybrid algorithm, called EDUK2. This algorithm takes advantage of the majority of the known properties of UKP, particularly the diverse dominance relations and the important periodicity property. Extensive computational results show that, in all but a very few cases, EDUK2 significantly outperforms both MTU2 and EDUK, the currently available UKP solvers, as well the well-known general purpose mathematical programming optimizer CPLEX of ILOG. These experimental results demonstrate that the class of hard UKP instances needs to be redefined, and the authors offer their insights into the creation of such instances.
