s'authentifier
version française rss feed
inria-00336189, version 1
Scheduling divisibleworkloads on heterogeneous platforms under bounded multi-port model
Olivier Beaumont () 12, Nicolas Bonichon 12, Lionel Eyraud-Dubois 12
Heterogeneity in Computing Workshop, in IEEE International Symposium on Parallel and Distributed Processing, 2008. IPDPS 2008. (2008)
Résumé : In this paper, we discuss complexity issues for scheduling divisible workloads on heterogeneous systems under the bounded multi-port model. To our best knowledge, this paper is the first attempt to consider divisible load scheduling under a realistic communication model, where the master node can communicate simultaneously to several slaves, provided that bandwidth constraints are not exceeded. In this paper, we concentrate on one round distribution schemes, where a given node starts its processing only once all data has been received. Our main contributions are (i) the proof that processors start working immediately after receiving their work (ii) the study of the optimal schedule in the case of 2 processors and (iii) the proof that scheduling divisible load under the bounded multi-port model is NP-complete. This last result strongly differs from divisible load literature and represents the first NP-completeness result when latencies are not taken into account.
  • 1 :  Laboratoire Bordelais de Recherche en Informatique (LaBRI)
  • CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB) – Université Victor Segalen - Bordeaux II
  • 2 :  CEPAGE (INRIA Bordeaux - Sud-Ouest)
  • INRIA – CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB)
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
  • inria-00336189, version 1
  • oai:hal.inria.fr:inria-00336189
  • Contributeur :
  • Soumis le : Lundi 3 Novembre 2008, 10:52:17
  • Dernière modification le : Vendredi 17 Juillet 2009, 11:48:24
tous les articles de la base du CCSd...
