Protocol for a Model-based Evaluation of a Dynamic Acoustic-to-Articulatory Inversion Method using Electromagnetic Articulography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Acoustic-to-articulatory maps based on articulatory models have typically been evaluated in terms of acoustic accuracy, that is, the distance between mapped and observed acoustic parameters. In this paper we present a method that would allow for the evaluation of such maps in the articulatory domain. The proposed method estimates the parameters of Maeda's articulatory model on the basis of electromagnetic articulograph data, thus producing full midsagittal views of the vocal tract from the positions of a limited number of sensors attached on articulators.
paperAsterios.pdf (191.47 Ko) Télécharger le fichier
inria-00336380 , version 1 (03-11-2008)
  • HAL Id : inria-00336380 , version 1
Asterios Toutios, Slim Ouni, Yves Laprie. Protocol for a Model-based Evaluation of a Dynamic Acoustic-to-Articulatory Inversion Method using Electromagnetic Articulography. The eighth International Seminar on Speech Production - ISSP'08, INRIA, Dec 2008, Strasbourg, France. ⟨inria-00336380⟩
221 Consultations
136 Téléchargements
