Constraints-based Verification of Parameterized Cryptographic Protocols. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Cryptographic protocols are crucial for securing electronic transactions. The confidence in these protocols can be increased by the formal analysis of their security properties. Although many works have been dedicated to standard protocols like Needham-Schroeder very few address the more challenging class of group protocols. We present a synchronous model for group protocols, that generalizes standard protocol models by permitting unbounded lists inside messages. In this extended model we propose a correct and complete set of inference rules for checking security properties in presence of an active intruder for the class of Well-Tagged protocols. We prove that the application of these rules on a constraint system terminates and that the normal form obtained can be checked for satisfiability. Therefore, we present here a decision procedure for this class.
RR-6712.pdf (760.74 Ko) Télécharger le fichier
inria-00336539 , version 1 (04-11-2008)
  • HAL Id : inria-00336539 , version 1
Najah Chridi, Mathieu Turuani, Michaël Rusinowitch. Constraints-based Verification of Parameterized Cryptographic Protocols.. [Research Report] RR-6712, INRIA. 2008, pp.54. ⟨inria-00336539⟩
149 Consultations
102 Téléchargements
