An IEEE 802.16 WiMAX Module for the NS-3 Simulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
ns-3 is a recently released next generation simulator intended as a replacement of the popular ns-2. It enables a highly rich set of features and is expected to become the first choice of the scientific community soon. ns-3 is in its evolution phase and work at different fronts is still ongoing. With the recent emergence of broadband wireless networks, simulation support for such networks, especially IEEE 802.16 WiMAX, is becoming a necessity. In this paper, we propose and discuss in detail the design and implementation of an IEEE 802.16 WiMAX module for ns-3, with the Point-to-Multipoint (PMP) mode and the WirelessMAN-OFDM PHY layer. Our module implements fundamental functions of the convergence sublayer (CS) and the MAC common-part sublayer (CPS), including QoS scheduling services, bandwidth request/grant mechanism, and a simple uplink scheduler. The aim is to provide a standard-compliant and well-designed implementation of the standard.
sigproc-sp.pdf (298.95 Ko) Télécharger le fichier
inria-00336858 , version 1 (05-11-2008)
  • HAL Id : inria-00336858 , version 1
Jahanzeb Farooq, Thierry Turletti. An IEEE 802.16 WiMAX Module for the NS-3 Simulator. [Technical Report] 2008, pp.11. ⟨inria-00336858⟩
Collections
INRIA INRIA2 LARA
202 Consultations
519 Téléchargements
