Basis Function Construction in Reinforcement Learning using Cascade-Correlation Learning Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In reinforcement learning, it is a common practice to map the state(-action) space to a different one using ba- sis functions. This transformation aims to represent the input data in a more informative form that facilitates and improves subsequent steps. As a "good" set of basis func- tions result in better solutions and defining such functions becomes a challenge with increasing problem complexity, it is beneficial to be able to generate them automatically. In this paper, we propose a new approach based on Bellman residual for constructing basis functions using cascade- correlation learning architecture. We show how this ap- proach can be applied to Least Squares Policy Iteration al- gorithm in order to obtain a better approximation of the value function, and consequently improve the performance of the resulting policies. We also present the effectiveness of the method empirically on some benchmark problems.
icmla08.pdf (132.49 Ko) Télécharger le fichier
hal-00826054 , version 1 (27-05-2013)
  • HAL Id : hal-00826054 , version 1
Sertan Girgin, Philippe Preux. Basis Function Construction in Reinforcement Learning using Cascade-Correlation Learning Architecture. International Conference on Machine Learning and Applications, Dec 2008, San Diego, United States. pp.75-82. ⟨hal-00826054⟩
187 Consultations
1336 Téléchargements
