Time Series Technical Analysis via New Fast Estimation Methods: A Preliminary Study in Mathematical Finance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
New fast estimation methods stemming from control theory lead to a fresh look at time series, which bears some resemblance to "technical analysis". The results are applied to a typical object of financial engineering, namely the forecast of foreign exchange rates, via a "model-free" setting, i.e., via repeated identifications of low order linear difference equations on sliding short time windows. Several convincing computer simulations, including the prediction of the position and of the volatility with respect to the forecasted trendline, are provided. $\mathcal{Z}$-transform and differential algebra are the main mathematical tools.
Coventry-Finance.pdf (585.56 Ko) Télécharger le fichier
inria-00338099 , version 1 (10-11-2008)
inria-00338099 , version 2 (15-11-2008)
  • HAL Id : inria-00338099 , version 2
  • ARXIV : 0811.1561
Michel Fliess, Cédric Join. Time Series Technical Analysis via New Fast Estimation Methods: A Preliminary Study in Mathematical Finance. IAR-ACD08 (23rd IAR Workshop on Advanced Control and Diagnosis), Nov 2008, Coventry, United Kingdom. ⟨inria-00338099v2⟩
769 Consultations
832 Téléchargements
