Semantics in Minimalist Categorial Grammar - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper is an attempt to develop a strictly derivationalist version of Chomsky's Minimalist Theory integrating theta roles and quantifier scoping without referring to a LF level. It is assumed different readings of a same sentence are obtained by various evaluation strategies, in a calculus which integrates a non deterministic version of lambda mu calculus
FGLecomte08.pdf (176.41 Ko) Télécharger le fichier
inria-00338495 , version 1 (13-11-2008)
  • HAL Id : inria-00338495 , version 1
Alain Lecomte. Semantics in Minimalist Categorial Grammar. FG 2008: The 13th conference on Formal Grammar, Aug 2008, Hamburg, Germany. ⟨inria-00338495⟩
99 Consultations
284 Téléchargements
