Unidirectional Chosen-Ciphertext Secure Proxy Re-Encryption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
In 1998, Blaze, Bleumer and Strauss introduced a cryptographic primitive called proxy re-encryption (PRE) in which a proxy can transform - without seeing the plaintext -- a ciphertext encrypted under one key into an encryption of the same plaintext under another key. The concept has recently drawn renewed interest. Notably, Canetti and Hohenberger showed how to properly define (and realize) chosen-ciphertext security for the primitive. Their system is bidirectional as the translation key allows converting ciphertexts in both directions. This paper presents the first unidirectional proxy re-encryption schemes with chosen-ciphertext security in the standard model (i.e. without the random oracle idealization). The first system provably fits a unidirectional extension of the Canetti-Hohenberger security model. As a second contribution, the paper considers a more realistic adversarial model where attackers may choose dishonest users' keys on their own. It is shown how to modify the first scheme to achieve security in the latter scenario. At a moderate expense, the resulting system provides additional useful properties such as non-interactive temporary delegations. Both constructions are efficient and rely on mild complexity assumptions in bilinear groups. Like the Canetti-Hohenberger scheme, they meet a relaxed flavor of chosen-ciphertext security introduced by Canetti, Krawczyk and Nielsen.
pre-long.pdf (322.5 Ko) Télécharger le fichier
inria-00339530 , version 1 (18-11-2008)
  • HAL Id : inria-00339530 , version 1
Benoît Libert, Damien Vergnaud. Unidirectional Chosen-Ciphertext Secure Proxy Re-Encryption. 2008. ⟨inria-00339530⟩
383 Consultations
1749 Téléchargements
