PBFilter: Indexing flash-resident data through par¬titioned summaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
NAND Flash has become the most popular persistent data storage medium for mobile and embedded devices. The hardware characteristics of NAND Flash (e.g. page granularity for read/write with a block-erase-before-rewrite constraint, limited number of erase cycles) preclude in-place updates. In this paper, we propose a new indexing scheme, called PBFilter, designed from the outset to exploit the peculiarities of NAND Flash.
YPM08.pdf (186.17 Ko) Télécharger le fichier
inria-00340715 , version 1 (24-11-2008)
  • HAL Id : inria-00340715 , version 1
Shaoyi Yin, Philippe Pucheral, Xiaofeng Meng. PBFilter: Indexing flash-resident data through par¬titioned summaries. 17th ACM International Conference on Information and Knowledge Management (ACM CIKM), Oct 2008, Napa Valley, United States. ⟨inria-00340715⟩
84 Consultations
97 Téléchargements
