Safe Longitudinal Platoons of Vehicles without Communication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Olivier Simonin
This report deals with the platooning problem that can be defined as the automatic following of a manned driven vehicle by a convoy of automatic ones. Different approaches have been proposed so far. Some require the localisation of each vehicle and a communication infrastructure, others called near-to-near approach only needs vehicle on-board sensors. However, to our knowledge, they do not provide any proof of non collision. We propose a novel near-to-near longitudinal platooning building a collision-free platooning whatever the number of vehicles. The model is derived from the study of the most dangerous interaction between two vehicles, i.e. considering the maximum acceptable acceleration when the previous vehicles brakes at maximum capacity. Collision avoidance of this model is proved. Finally, we show that this model can be combined to existing ones, keeping this collision-free property while allowing more various behaviors.
RR-6741.pdf (358.79 Ko) Télécharger le fichier
inria-00342719 , version 1 (28-11-2008)
  • HAL Id : inria-00342719 , version 1
Alexis Scheuer, Olivier Simonin, François Charpillet. Safe Longitudinal Platoons of Vehicles without Communication. [Research Report] RR-6741, INRIA. 2008, pp.24. ⟨inria-00342719⟩
163 Consultations
218 Téléchargements
