OPTIMISATION OF EXTRUDED POLYMER FOAM BY THE RESIDENT TIME DISTRIBUTION APPROACH - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this work, we used the Residence Time Distribution (RTD) to study the polystyrene foaming during an extrusion process. The extruder associated with a gear pump is simply and quantitatively described by three continuoustly stirred tank reactors with recycling loops and one plug-flow reactor. The blowing agent used is CO2 and its obtained by ther- mal decomposition of a chemical blowing agent (CBA). This approach allows to optimize the density of the foam in accordance with the CBA kinetic of decomposition
Prc_PPS_24_A.pdf (572.96 Ko) Télécharger le fichier
inria-00342785 , version 1 (28-11-2008)
  • HAL Id : inria-00342785 , version 1
Frédéric Léonardi, Mathieu Larochette, Djamel Nasri, Didier Graebling. OPTIMISATION OF EXTRUDED POLYMER FOAM BY THE RESIDENT TIME DISTRIBUTION APPROACH. the Polymer Processing Society 24th Annual Meeting, Jun 2008, salerno, Italy. ⟨inria-00342785⟩
162 Consultations
231 Téléchargements
