Advance reservation of resources for task execution in grid environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The paper proposes a solution for the Grid scheduling problem, addressing in particular the requirement of high performance an efficient algorithm must fulfill. Advance Reservation engages a distributed, dynamic, fault-tolerant and efficient strategy which reserves resources for future task execution. The paper presents the main features of the strategy, the functioning mechanism the strategy is based on and the methods used for evaluating the algorithm.
AR-article.pdf (280.56 Ko) Télécharger le fichier
inria-00343780 , version 1 (02-12-2008)
  • HAL Id : inria-00343780 , version 1
Izabela Moise, Diana Moise, Florin Pop, Valentin Cristea. Advance reservation of resources for task execution in grid environments. The Second International Workshop on High Performance in Grid Middleware (HiPerGRID 2008), Nov 2008, Bucharest, Romania. ⟨inria-00343780⟩
127 Consultations
113 Téléchargements
