Exact rounding for geometric constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
Hervé Brönnimann
  • Fonction : Auteur
  • PersonId : 830812
Sylvain Pion
Exact rounding is provided for elementary floating-point arithmetic operations (e.g. in the IEEE standard). Many authors have felt that it should be provided for other operations, in particular for geometric constructions. We show how one may round modular representation of numbers to the closest f.p. representable number, and demonstrate how it can be applied to a variety of geometric constructions. Our methods use only single precision; they produce compact, efficient, and highly parallelizable code. We suggest that they can be applied in other settings when exact computations interact closely with rounded representations.
SCAN.pdf (97.39 Ko) Télécharger le fichier
inria-00344403 , version 1 (04-12-2008)
  • HAL Id : inria-00344403 , version 1
Hervé Brönnimann, Sylvain Pion. Exact rounding for geometric constructions. Scientific Computing, Computer Arithmetic and Validated Numerics (SCAN), 1997, Lyon, France. ⟨inria-00344403⟩
Collections
INRIA INRIA2
25 Consultations
33 Téléchargements
