The design of the Boost interval arithmetic library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2006
Sylvain Pion
We present the design of the Boost interval arithmetic library, a C++ library designed to efficiently handle mathematical intervals in a generic way. Interval computations are an essential tool for reliable computing. Increasingly a number of mathematical proofs have relied on global optimization problems solved using branch-and-bound algorithms with interval computations; it is therefore extremely important to have a mathematically correct implementation of interval arithmetic. Various implementations exist with diverse semantics. Our design is unique in that it uses policies to specify three independent variable behaviors: rounding, checking, comparisons. As a result, with the proper policies, our interval library is able to emulate almost any of the specialized libraries available for interval arithmetic, without any loss of performance nor sacrificing the ease of use. This library is openly available at www.boost.org.
tcs.pdf (194.12 Ko) Télécharger le fichier
inria-00344412 , version 1 (04-12-2008)
Hervé Brönnimann, Guillaume Melquiond, Sylvain Pion. The design of the Boost interval arithmetic library. Theoretical Computer Science, 2006, Real Numbers and Computers, 351 (1), pp.111-118. ⟨10.1016/j.tcs.2005.09.062⟩. ⟨inria-00344412⟩
362 Consultations
393 Téléchargements
