Computational study and sensitivity analysis for quality modeling in Water Distribution Systems. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Journal of Hydraulic Engineering Année : 2009
In this paper, direct water quality modelling and the associated unsteady sensitivity equations, are solved in Water Distribution Systems (WDS). A new solution algorithm is proposed, based on a time splitting method to separate and solve efficiently each phenomenon such as advection and chemical reaction. This numerical approach allows a simultaneous solution of both the direct problem and the sensitivity equations. Special attention is given to the treatment of advection, which is handled with a Total Variation Diminishing (TVD) scheme. \\ The general model presented in this study permits a global sensitivity analysis of the system and its efficiency is illustrated on two pipe networks. The importance of the sensitivity analysis is shown as part of a fitting process on a real network.
Article_JHYE.pdf (334.46 Ko) Télécharger le fichier
inria-00346976 , version 1 (13-12-2008)
  • HAL Id : inria-00346976 , version 1
Pierre Fabrie, Guillaume Gancel, Iraj Mortazavi, Olivier Piller. Computational study and sensitivity analysis for quality modeling in Water Distribution Systems.. 2008. ⟨inria-00346976⟩
180 Consultations
298 Téléchargements
