On the Almost Sure Central Limit Theorem for Vector Martingales: Convergence of Moments and Statistical Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We investigate the almost sure asymptotic properties of vector martingale transforms. Assuming some appropriate regularity conditions both on the increasing process and on the moments of the martingale, we prove that normalized moments of any even order converge in the almost sure cental limit theorem for martingales. A conjecture about almost sure upper bounds under wider hypotheses is formulated. The theoretical results are supported by examples borrowed from statistical applications, including linear autoregressive models and branching processes with immigration, for which new asymptotic properties are established on estimation and prediction errors.
RR-6780.pdf (263.36 Ko) Télécharger le fichier
inria-00348138 , version 1 (17-12-2008)
  • HAL Id : inria-00348138 , version 1
  • ARXIV : 0812.3528
Bernard Bercu, Peggy Cénac, Guy Fayolle. On the Almost Sure Central Limit Theorem for Vector Martingales: Convergence of Moments and Statistical Applications. [Research Report] RR-6780, INRIA. 2008, pp.26. ⟨inria-00348138⟩
345 Consultations
429 Téléchargements
