s'authentifier
version française rss feed
inria-00348715, version 1
Constructive Root Bound for k-Ary Rational Input Numbers
Sylvain Pion () 12, Chee K. Yap 2
19th Annual ACM Symposium on Computational Geometry (SCG) (2003) 256-263
Résumé : Constructive root bounds is the fundamental technique needed to achieve guaranteed accuracy, the critical capability in Exact Geometric Computation. Known bounds are overly pessimistic in the presence of general rational input numbers. In this paper, we introduce a method which greatly improves the known bounds for k-ary rational input numbers. Since majority of input numbers in scientific and engineering applications are such numbers, this could lead to a significant speedup for a large class of applications. We apply our method to the BFMSS Bound. Implementation and experimental results based on the CORE library are reported.
  • Domaine : Informatique/Géométrie algorithmique
    Informatique/Arithmétique des ordinateurs
  • Mots-clés : Constructive root bounds – exact geometric computation – robust numerical algorithms – k-ary rational numbers
  • inria-00348715, version 1
  • oai:hal.inria.fr:inria-00348715
  • Contributeur :
  • Soumis le : Samedi 20 Décembre 2008, 21:07:45
  • Dernière modification le : Mercredi 11 Février 2009, 16:46:10
tous les articles de la base du CCSd...
