A photometric model for specular highlights and lighting changes. Application to feature points tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This article proposes a local photometric model that compensates for specular highlights and lighting variations due to position and intensity changes. We define clearly on which assumptions it is based, according to widely used reflection models. Moreover, its theoritical validity is studied according to few configurations of the scene geometry (lighting, camera and object relative locations). Next, this model is used to improve the robustness of points tracking in luminance images with respect to specular highlights and lighting changes.
2006_icip_gouiffes.pdf (222 Ko) Télécharger le fichier
inria-00350293 , version 1 (06-01-2009)
  • HAL Id : inria-00350293 , version 1
M. Gouiffès, Christophe Collewet, Christine Fernandez-Maloigne, A. Trémeau. A photometric model for specular highlights and lighting changes. Application to feature points tracking. IEEE Int. Conf. on Image Processing, ICIP'2006, 2006, Atlanta, Georgia, France. pp.2117-2120. ⟨inria-00350293⟩
176 Consultations
188 Téléchargements
