Through-the-eyes control of a virtual humano? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The aim of this paper is to present a new animation technique to control a humano?in a virtual environment. This control technique is issued from a need to simplify input parameters for automatic generation of motions, according to the simulation of the visual perception for a synthetic humano? The proposed method is founded on an image-based technique or more commonly called in the robotic field visual servoing. It consists in controlling the humano?s motions through the image it ``perceives''. This approach is dedicated to highly reactive contexts (video games, virtual reality), as far as it is based on a closed loop system. We also discuss of the integration of such a technique in a more complex behavioural system.
2001_ca_courty.pdf (768.1 Ko) Télécharger le fichier
inria-00352123 , version 1 (12-01-2009)
  • HAL Id : inria-00352123 , version 1
Nicolas Courty, E. Marchand, Bruno Arnaldi. Through-the-eyes control of a virtual humano?. IEEE Computer Animation 2001, 2001, Seoul, Korea, France. pp.74-83. ⟨inria-00352123⟩
106 Consultations
103 Téléchargements
