Active vision for complete scene reconstruction and exploration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 1999
This paper deals with the 3D structure estimation and exploration of static scenes using active vision. Our method is based on the structure from controlled motion approach that constrains camera motions to obtain an optimal estimation of the 3D structure of a geometrical primitive. Since this approach involves gazing on the considered primitive, we have developed perceptual strategies able to perform a succession of robust estimations. This leads to a gaze planning strategy that mainly uses a representation of known and unknown areas as a basis for selecting viewpoints. This approach ensures a reconstruction as complete as possible of the scene
Mots clés
1999_ieeepami_marchand.pdf (514.31 Ko) Télécharger le fichier
inria-00352545 , version 1 (13-01-2009)
  • HAL Id : inria-00352545 , version 1
E. Marchand, François Chaumette. Active vision for complete scene reconstruction and exploration. IEEE Transactions on Pattern Analysis and Machine Intelligence, 1999, 21 (1), pp.65-72. ⟨inria-00352545⟩
244 Consultations
291 Téléchargements
