Interactive Modeling of Mushrooms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a fast and efficient method for modeling mushrooms. Starting from a real world image, the designer defines a silhouette and specifies deformation parameters. Our system then automatically generates a textured triangle mesh model using a procedural modeling pipeline. This approach enables us to create a vast variety of shapes easily using shape morphing.
mushroom-2004.pdf (1.14 Mo) Télécharger le fichier
Format : Figure, Image
inria-00355626 , version 1 (29-04-2011)
  • HAL Id : inria-00355626 , version 1
Brett Desbenoit, David Vanderhaeghe, Eric Galin, J. Grosjean. Interactive Modeling of Mushrooms. Eurographics (short papers), Eurographics, Aug 2004, Grenoble, France. pp.37-40. ⟨inria-00355626⟩
225 Consultations
185 Téléchargements
