Fast algorithms for differential equations in positive characteristic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
Alin Bostan
  • Fonction : Auteur
  • PersonId : 831654
Éric Schost
  • Fonction : Auteur
  • PersonId : 839026
We address complexity issues for linear differential equations in characteristic~$p>0$: resolution and computation of the $p$-curvature. For these tasks, our main focus is on algorithms whose complexity behaves well with respect to~$p$. We prove bounds linear in $p$ on the degree of polynomial solutions and propose algorithms for testing the existence of polynomial solutions in sublinear time $\tilde{O}(p^{1/2})$, and for determining a whole basis of the solution space in quasi-linear time $\tilde{O}(p)$; the $\tilde{O}$ notation indicates that we hide logarithmic factors. We show that for equations of arbitrary order, the $p$-curvature can be computed in subquadratic time $\tilde{O}(p^{1.79})$, and that this can be improved to $O(\log(p))$ for first order equations and to $\tilde{O}(p)$ for classes of second order equations.
BoSc09.pdf (221.43 Ko) Télécharger le fichier
inria-00355818 , version 1 (24-01-2009)
  • HAL Id : inria-00355818 , version 1
  • ARXIV : 0901.3843
Alin Bostan, Éric Schost. Fast algorithms for differential equations in positive characteristic. 2009. ⟨inria-00355818⟩
Collections
INRIA INRIA2 ANR
78 Consultations
98 Téléchargements
