On MPR-OSPF Specification and Implementation in Quagga/GTNetS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This document analyses the MPR-OSPF current specification and compares it with the implemented version for the Quagga / Zebra routing suite, adapted for the GTNetS network simulator. It presents the relationship between Quagga/Zebra core and the GTNetS simulation framework, describes the inner architecture of the MPR-OSPF extension in the OSPF Quagga general implementation and identifies the different protocol main elements in the implemented code.
RR-6827.pdf (519.57 Ko) Télécharger le fichier
inria-00359138 , version 1 (05-02-2009)
  • HAL Id : inria-00359138 , version 1
Juan Antonio Cordero. On MPR-OSPF Specification and Implementation in Quagga/GTNetS. [Research Report] RR-6827, INRIA. 2008, pp.37. ⟨inria-00359138⟩
171 Consultations
386 Téléchargements
