A Unified Algorithm for Accelerating Edit-Distance Computation via Text-Compression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present a unified framework for accelerating edit-distance computation between two compressible strings using straight-line programs. For two strings of total length $N$ having straight-line program representations of total size $n$, we provide an algorithm running in $O(n^{1.4}N^{1.2})$ time for computing the edit-distance of these two strings under any rational scoring function, and an $O(n^{1.34}N^{1.34})$ time algorithm for arbitrary scoring functions. This improves on a recent algorithm of Tiskin that runs in $O(nN^{1.5})$ time, and works only for rational scoring functions. Also, in the last part of the paper, we show how the classical four-russians technique can be incorporated into our SLP edit-distance scheme, giving us a simple $\Omega(\lg N)$ speed-up in the case of arbitrary scoring functions, for any pair of strings.
Hermelin_new.pdf (298.43 Ko) Télécharger le fichier
inria-00360821 , version 1 (16-02-2009)
  • HAL Id : inria-00360821 , version 1
  • ARXIV : 0902.2649
Danny Hermelin, Gad M. Landau, Shir Landau, Oren Weimann. A Unified Algorithm for Accelerating Edit-Distance Computation via Text-Compression. 26th International Symposium on Theoretical Aspects of Computer Science - STACS 2009, Feb 2009, Freiburg, Germany. pp.529-540. ⟨inria-00360821⟩
Collections
STACS2009
73 Consultations
93 Téléchargements
