s'authentifier
version française rss feed
inria-00369580, version 1
Circulant and Toeplitz Matrices in Compressed Sensing
Holger Rauhut () 1
SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations (2009)
Résumé : Compressed sensing seeks to recover a sparse vector from a small number of linear and non-adaptive measurements. While most work so far focuses on Gaussian or Bernoulli random measurements we investigate the use of partial random circulant and Toeplitz matrices in connection with recovery by `1-minization. In contrast to recent work in this direction we allow the use of an arbitrary subset of rows of a circulant and Toeplitz matrix. Our recovery result predicts that the necessary number of measurements to ensure sparse reconstruction by `1-minimization with random partial circulant or Toeplitz matrices scales linearly in the sparsity up to a log-factor in the ambient dimension. This represents a significant improvement over previous recovery results for such matrices. As a main tool for the proofs we use a new version of the non-commutative Khintchine inequality.
  • Domaine : Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • inria-00369580, version 1
  • oai:hal.inria.fr:inria-00369580
  • Contributeur :
  • Soumis le : Vendredi 20 Mars 2009, 13:47:48
  • Dernière modification le : Vendredi 20 Mars 2009, 13:54:17
tous les articles de la base du CCSd...
