s'authentifier
version française rss feed
inria-00369782, version 1
A Statistical Learning Perspective of Genetic Programming}
Merve Amil 123, Nicolas Bredeche () 123, Christian Gagné () 123, Sylvain Gelly 123, Marc Schoenauer () 123, Olivier Teytaud () 123
EuroGP (2009)
Résumé : This paper proposes a theoretical analysis of Genetic Programming (GP) from the perspective of statistical learning theory, a well grounded mathematical toolbox for machine learning. By computing the Vapnik-Chervonenkis dimension of the family of programs that can be inferred by a specific setting of GP, it is proved that a parsimonious fitness ensures universal consistency. This means that the empirical error minimization allows convergence to the best possible error when the number of test cases goes to infinity. However, it is also proved that the standard method consisting in putting a hard limit on the program size still results in programs of infinitely increasing size in function of their accuracy. It is also shown that cross-validation or hold-out for choosing the complexity level that optimizes the error rate in generalization also leads to bloat. So a more complicated modification of the fitness is proposed in order to avoid unnecessary bloat while nevertheless preserving universal consistency.
  • Domaine : Mathématiques/Optimisation et contrôle
  • inria-00369782, version 1
  • oai:hal.inria.fr:inria-00369782
  • Contributeur :
  • Soumis le : Samedi 21 Mars 2009, 09:09:26
  • Dernière modification le : Samedi 21 Mars 2009, 09:17:06
tous les articles de la base du CCSd...
