s'authentifier
version française rss feed
inria-00374910, version 1
Optimal robust expensive optimization is tractable
Philippe Rolet () 12, Michèle Sebag () 12, Olivier Teytaud () 12
Gecco 2009 (2009) 8 pages
Résumé : Following a number of recent papers investigating the possibility of optimal comparison-based optimization algorithms for a given distribution of probability on fitness functions, we (i) discuss the comparison-based constraints (ii) choose a setting in which theoretical tight bounds are known (iii) develop a careful implementation using billiard algorithms, Upper Confidence trees and (iv) experimentally test the tractability of the approach. The results, on still very simple cases, show that the approach, yet still preliminary, could be tested successfully until dimension 10 and horizon 50 iterations within a few hours on a standard computer, with convergence rate far better than the best algorithms.
  • Domaine : Mathématiques/Optimisation et contrôle
  • inria-00374910, version 1
  • oai:hal.inria.fr:inria-00374910
  • Contributeur :
  • Soumis le : Vendredi 10 Avril 2009, 11:38:16
  • Dernière modification le : Vendredi 10 Avril 2009, 11:41:12
tous les articles de la base du CCSd...
