Accurate Specular Reflections in Real-Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2006
Specular reflections provide many important visual cues in our daily environment. They inform us of the shape of objects, of the material they are made of, of their relative positions, etc. Specular reflections on curved objects are usually approximated using environment maps. In this paper, we present a new algorithm for real-time computation of specular reflections on curved objects, based on an exact computation for the reflection of each scene vertex. Our method exhibits all the required parallax effects and can handle arbitrary proximity between the reflector and the reflected objects.
final_electronic.pdf (6.1 Mo) Télécharger le fichier
final_paper.pdf (6.1 Mo) Télécharger le fichier
realtimeSpec.avi (34.65 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00379310 , version 1 (28-04-2009)
David Roger, Nicolas Holzschuch. Accurate Specular Reflections in Real-Time. Computer Graphics Forum, 2006, 25 (3), pp.293 - 302. ⟨10.1111/j.1467-8659.2006.00948.x⟩. ⟨inria-00379310⟩
244 Consultations
1097 Téléchargements
