Modeling an agrifood industrial process using cooperative coevolution Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This report presents two experiments related to the modeling of an industrial agrifood process using evolutionary techniques. Experiments have been focussed on a specific problem which is the modeling of a Camembert-cheese ripening process. Two elated complex optimisation problems have been considered: -- a deterministic modeling problem, the phase prediction roblem, for which a search for a closed form tree expression has been performed using genetic programming (GP), -- a Bayesian network structure estimation problem, considered as a two-stage problem, i.e. searching first for an approximation of an independence model using EA, and then deducing, via a deterministic algorithm, a Bayesian network which represents the equivalence class of the independence model found at the first stage. In both of these problems, cooperative-coevolution techniques (also called ``Parisian'' approaches) have been proved successful. These approaches actually allow to represent the searched solution as an aggregation of several individuals (or even as a whole population), as each individual only bears a part of the searched solution. This scheme allows to use the artificial Darwinism principles in a more economic way, and the gain in terms of robustness and efficiency is important.
RR2008.pdf (919.08 Ko) Télécharger le fichier
inria-00381681 , version 1 (06-05-2009)
  • HAL Id : inria-00381681 , version 1
  • PRODINRA : 249719
Olivier Barrière, Evelyne Lutton, Pierre-Henri Wuillemin, Cédric Baudrit, Mariette Sicard, et al.. Modeling an agrifood industrial process using cooperative coevolution Algorithms. [Research Report] RR-6914, INRIA. 2009, pp.51. ⟨inria-00381681⟩
297 Consultations
231 Téléchargements
