Syntax and Semantics of the Clock Constraint Specification Language (CCSL) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The UML Profile for Modeling and Analysis of Real-Time and Embedded (MARTE) systems has recently been adopted by the OMG. Its Time Model extends the informal and simplistic Simple Time package proposed by UML2 and offers a broad range of capabilities required to model real-time systems. The MARTE OMG specification introduces a Time Structure inspired from Time models of the concurrency theory and proposes a new clock constraint specification language (CCSL) to specify, within the context of UML, logical and chronometric time constraints. This report specifies the syntax and a formal semantics of a subset of CCSL, called kernel CCSL. This semantics is to be the reference semantics of CCSL.
RR-6925.pdf (538.2 Ko) Télécharger le fichier
inria-00384077 , version 1 (14-05-2009)
inria-00384077 , version 2 (15-06-2009)
  • HAL Id : inria-00384077 , version 2
Charles André. Syntax and Semantics of the Clock Constraint Specification Language (CCSL). [Research Report] RR-6925, INRIA. 2009, pp.37. ⟨inria-00384077v2⟩
1177 Consultations
1286 Téléchargements
