A Line-Based Data Dissemination protocol for Wireless Sensor Networks with Mobile Sink - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In wireless sensor networks, data dissemination is generally performed from the sensor nodes towards a static sink. In this paper, we address the particular case where the sink is mobile, according to an unpredictable mobility pattern. First, we study existing approaches. As an alternative, we present the Line-Based Data Dissemination (LBDD) protocol. Next, we analytically evaluate the communication cost of this protocol and we compare it to other approaches. Finally, realistic simulations are performed and results show that LBDD outperforms previous approaches and presents the best tradeoff among the evaluated protocols.
icc2008.pdf (171.99 Ko) Télécharger le fichier
inria-00384139 , version 1 (14-05-2009)
Elyes Ben Hamida, Guillaume Chelius. A Line-Based Data Dissemination protocol for Wireless Sensor Networks with Mobile Sink. IEEE International Conference on Communications (ICC 2008), IEEE, May 2008, Beijing, China. pp.2201 - 2205, ⟨10.1109/ICC.2008.420⟩. ⟨inria-00384139⟩
165 Consultations
813 Téléchargements
