3D SSD tracking with estimated 3D planes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Image and Vision Computing Année : 2009
We present a tracking method where full camera position and orientation is tracked from intensity differences in a video sequence. The camera pose is calculated based on 3D planes, and hence does not depend on point correspondences. The plane based formulation also allows additional constraints to be naturally added, e.g., perpendicularity between walls, floor and ceiling surfaces, co-planarity of wall surfaces etc. A particular feature of our method is that the full 3D pose change is directly computed from temporal image differences without making a commitment to a particular intermediate (e.g., 2D feature) representation. We experimentally compared our method with regular 2D SSD tracking and found it more robust and stable. This is due to 3D consistency being enforced even in the low level registration of image regions. This yields better results than first computing (and hence committing to) 2D image features and then from these compute 3D pose.
inria-00384230 , version 1 (14-05-2009)
Dana Cobzas, Martin Jägersand, Peter Sturm. 3D SSD tracking with estimated 3D planes. Image and Vision Computing, 2009, Canadian Robotic Vision 2005 and 2006, 27 (1), pp.69-79. ⟨10.1016/j.imavis.2006.10.008⟩. ⟨inria-00384230⟩
1518 Consultations
0 Téléchargements
