The Navier-Stokes-Vlasov-Fokker-Planck system near equilibrium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2010
This paper is concerned with a system that couples the incompressible Navier-Stokes equations to the Vlasov-Fokker-Planck equation. Such a system arises in the modeling of sprays, where a dense phase interacts with a disperse phase. The coupling arises from the Stokes drag force exerted by a phase on the other. We study the global-in-time existence of classical solutions for data close to an equilibrium. We investigate further regularity properties of the solutions as well as their long time behavior. The proofs use energy estimates and the hypoelliptic structure of the system.
nsvp_12_March_09.pdf (270.34 Ko) Télécharger le fichier
inria-00384364 , version 1 (16-05-2009)
Thierry Goudon, Lingbing He, Ayman Moussa, Ping Zhang. The Navier-Stokes-Vlasov-Fokker-Planck system near equilibrium. SIAM Journal on Mathematical Analysis, 2010, 42 (5), ⟨10.1137/090776755⟩. ⟨inria-00384364⟩
354 Consultations
576 Téléchargements
