s'authentifier
version française rss feed
inria-00385608, version 1
Generalised Weber Functions. I
Andreas Enge () 1, François Morain () 23
(2009)
Résumé : A generalised Weber function is given by $\w_N(z) = \eta(z/N)/\eta(z)$, where $\eta(z)$ is the Dedekind function and $N$ is any integer; the original function corresponds to $N=2$. We classify the cases where some power $\w_N^e$ evaluated at some quadratic integer generates the ring class field associated to an order of an imaginary quadratic field. We compare the heights of our invariants by giving a general formula for the degree of the modular equation relating $\w_N(z)$ and $j(z)$.
  • Domaine : Mathématiques/Théorie des nombres
  • Mots-clés : Weber function – complex multiplication – class invariant
  • inria-00385608, version 1
  • oai:hal.inria.fr:inria-00385608
  • Contributeur :
  • Soumis le : Mardi 19 Mai 2009, 16:28:57
  • Dernière modification le : Jeudi 24 Septembre 2009, 22:33:51
tous les articles de la base du CCSd...
