Classification divisive sous contraintes. Application au bassin de la Charente - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
DIVCLUS-T is a descendant hierarchical clustering algorithm based on a monothetic bipartitional approach allowing the dendrogram of the hierarchy to be read as a decision tree. We propose in this paper a new version of this method called C-DIVCLUS-T which is able to take contiguity constraints into account. We apply C-DIVCLUS-T to hydrological areas described by agricultural and environmental variables, in order to take their geographical contiguity into account in the monothetic clustering process.
p235.pdf (296.22 Ko) Télécharger le fichier
inria-00386792 , version 1 (22-05-2009)
  • HAL Id : inria-00386792 , version 1
Marie Chavent, Yves Lechevallier, Kévin Petit, Françoise Vernier. Classification divisive sous contraintes. Application au bassin de la Charente. 41èmes Journées de Statistique, SFdS, May 2009, Bordeaux, France. ⟨inria-00386792⟩
108 Consultations
247 Téléchargements
