inria-00388957, version 1
STKM on SCA: a Unified Framework with Components, Workflows and Algorthmic Skeletons
Marco Aldinucci a, 1Hinde Lilia Bouziane
b, 2Marco Danelutto 3Christian Pérez
c, 2
15th International European Conference on Parallel and Distributed Computing (Euro-Par 2009), (2009)
Résumé : This paper investigates an implementation of S TKM, a Spatio-Temporal sKeleton Model. S TKM expands the Grid Component Model (G CM) with an innovative programmable approach that allows programmers to compose an application by combining component, workflow and skeleton concepts. The paper deals with a projection of the S TKM model on top of S CA and it evaluates its implementation using Tuscany Java S CA. Experimental results show the need and the benefits of the high level of abstraction offered by S TKM.
- a – University of Torino
- b – Université Claude Bernard - Lyon I
- c – INRIA
- 1 : Dipartimento di Informatica [Torino]
- Università di Torino
- 2 : GRAAL (INRIA Grenoble Rhône-Alpes / LIP Laboratoire de l'Informatique du Parallélisme)
- CNRS : UMR5668 – INRIA – École Normale Supérieure - Lyon – Université Claude Bernard - Lyon I – Laboratoire d'informatique du Parallélisme
- 3 : Department of Computer Science [Pisa]
- UNIVERSITÀ DEGLI STUDI DI PISA
- Domaine : Informatique/Calcul parallèle, distribué et partagé
- inria-00388957, version 1
- http://hal.inria.fr/inria-00388957
- oai:hal.inria.fr:inria-00388957
- Contributeur : Christian Perez
- Soumis le : Mercredi 27 Mai 2009, 17:34:27
- Dernière modification le : Mercredi 27 Mai 2009, 17:34:27
Exporter
