Local Existence and Uniqueness of a Mild Solution to the One Dimensional Vlasov-Poisson System with an Initial Condition of Bounded Variation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We propose a result of local existence and uniqueness of a mild solution to the one-dimensional Vlasov-Poisson system. We establish the result for an initial condition lying in the Sobolev space of integrable functions with integrable derivatives, then we extend it to initial conditions lying in the space of functions of bounded variation, without any assumption of continuity, boundedness or compact support.
RR-6946.pdf (237.57 Ko) Télécharger le fichier
inria-00389829 , version 1 (29-05-2009)
  • HAL Id : inria-00389829 , version 1
Simon Labrunie, Sandrine Marchal, Jean Rodolphe Roche. Local Existence and Uniqueness of a Mild Solution to the One Dimensional Vlasov-Poisson System with an Initial Condition of Bounded Variation. [Research Report] RR-6946, INRIA. 2009, pp.14. ⟨inria-00389829⟩
379 Consultations
156 Téléchargements
