An algebraic derivative-based approach for the zero-crossings estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
A new approach to the design of a zero-crossings estimation algorithm is proposed. The approach uses elementary differential algebraic operations in the frequency domain for accu- rate derivative estimation. Such estimates are composed of iterated integrals of noisy observed signal. A detector-signal, which is exactly equal to zero when there is no intersection between the observed signal and the real axis and is greater than zero when a zero-crossing occurs, is obtained. To justify the theoretical analysis and to investigate the performances of the developed method, simulated experiments are performed.
Automatique
518236434.pdf (131.87 Ko) Télécharger le fichier
inria-00389872 , version 1 (29-05-2009)
  • HAL Id : inria-00389872 , version 1
Giuseppe Fedele, Francesco Chiaravalloti, Cédric Join. An algebraic derivative-based approach for the zero-crossings estimation. 17th European Signal Processing Conference, EUSIPCO 2009, Aug 2009, Glasgow, United Kingdom. ⟨inria-00389872⟩
444 Consultations
693 Téléchargements
