s'authentifier
version française rss feed
inria-00390416, version 1
Lasalle's Invariance Theorem for Nonsmooth Lagrangian Dynamical Systems
Sophie Chareyron 1, Pierre-Brice Wieber () a1
Euromech Nonlinear Dynamics Conference (2005)
Résumé : A key condition for the statement of Lasalle's invariance theorem is the continuity of the trajectories of the dynamical systems with respect to initial conditions. Systems with discontinuous flows generally don't present such a continuity, but in the particular case of nonsmooth Lagrangian dynamical systems we will see that in fact this continuity property holds in most cases. We will then be able to propose a a LaSalle's invariance theorem for nonsmooth dynamical systems satisfying this property through the use of general time-invariant flows.orem for nonsmooth dynamical systems still needs to be stated, so we propose here to extend this theorem through the framework of nonsmooth dynamical systems.
  • Domaine : Informatique/Robotique
    Informatique/Automatique
  • inria-00390416, version 1
  • oai:hal.inria.fr:inria-00390416
  • Contributeur :
  • Soumis le : Mardi 2 Juin 2009, 10:07:12
  • Dernière modification le : Vendredi 12 Juin 2009, 15:29:56
tous les articles de la base du CCSd...
